Old 08-03-2009, 10:38 PM
Tiny Tiny is offline
Default Re: 74 20 Scepter 130 yamaha new tank, re-wired, solid
$4300 btt
Old 08-08-2009, 09:52 PM
$4100 BTT
Old 08-11-2009, 11:00 PM
$4000 BTT
Old 08-14-2009, 09:35 PM
Matt Matt is offline
Bump! Clean little rig. I can't believe somebody hasn't moved on this.
Old 08-17-2009, 09:40 PM
Thanks Matt.
$3900 btt
Old 08-21-2009, 02:18 PM
SOLD!!! to a nice guy who drove from Texas to sea trial her and pick her up. She found a good home for sure! To the rest of you, thanks for looking!
We'll still be on here, because we replaced her with a 20 IO safari :-). These are such great boats.
Old 08-21-2009, 05:39 PM
Congrats on the sale, I was reviewing your fuel numbers - nearly 50% better than I'm getting on the Seafari w/ a 115 I-6. I suppose you'll do even better w/ the i/o setup...good luck w/ it.
Old 08-21-2009, 10:04 PM
I don't mean to sound like a MPG pervert :-)...but I'm getting over 5 mpg in ideal conditions, top down, trimmed up and over 3.5mpg loaded for bear, both tops up, 4 guys, when it's rough (and we can still plane) with the IO. Even doggin it she does very well. For a cheap outboard rig, the one I just sold was awesome...for an IO the one I have now rocks...
When gas is $5 a gallon I'll still be fishing and Freediving! Tight lines.
Old 08-22-2009, 04:28 PM
Default bushwacker
Those numbers for the I/O sound about right; you might check them vs. the Boating magazine article in the Literature section. It's a pretty efficient rig despite the ancient technology engine. The modern 4 stroke outboards aren't much better! 2 different I/O Seafari's have made the run with me to Green Turtle Cay in the Abaco's, via Walkers Cay as I remember. They both burned about 45 gallons vs. about 65 gallons for my old 115 2-stroke. Distance was about 160 nm. That works out to about 4 statute mpg for the I/O vs. about 2.8 for mine. This was with a heavy load with all the gear you'd need for a 2 wk trip, running in the 2' square waves typical of the little Bahama bank, cruising at about 20 kts, which is probably a little faster than optimum for that rig.
