![]() Quote:
Oh yeah. It's easier if the tank is removed.
Job done. Brought the hose up from the tank with tie wraps connecting both inch and one half hoses. Secret....spray lots of SILICONE spray on the hoses, near the connection. Slipped right on through up to the fill port on the gunwale.
Next, I have to do the vent hose. |
![]() Quote:
Any recommendation out there?
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
![]() Quote:
Vent hose is in. A messy job putting both these hoses in but
it needed to be done. Ethanol in the fuel really did a job on the fuel filler hose. It was more or less rotted out. |
![]() Quote:
20' Mako 175 'rude Sacto, CA looking for a landlocked 23'-25' Seacraft ![]() http://classicmako.com/forum/topic.asp?TOPIC_ID=13979 |
![]() Quote:
When I replaced the fill and vent hoses on my Tsunami,I figured that it would be a nightmare.
The opposite was true.After I pulled the hatch cover,cleaned,inspected,and re-installed the tank,it was just a matter of connecting the new hoses to the old,with a a piece of tube and some hose clamps,and pulling them through. I removed the fill port,and pulled the old hose,and new hose out from the tank,under the deck,and up the pillar,to the gunwale as one piece.Discarded the old hose,cut the new hose to length,and attached it to the fill port,and tank and re-installed it.Did the same with the vent hose. Other than a little bit of a PIA getting at the screws,it was pretty easy. ![]()
![]() Quote:
Nope,the vent went out pretty high.I was able to get to it,by reaching up under the gunwale,just to the front of the pillar a little bit.I had to go down,with my hand a bit,then I was able to push it up,and on.
I did cut up my hand a bit on some rough glass,but i was able to slide the hose on to the vent and clamp it.I don't know,maybe I just got lucky. Here's where my vent is,you can see it,just under the blue horizontal scaffold tube.It still has the masking tape on it,looks like a nub. ![]()
