Old 09-29-2009, 08:39 AM
Greno Greno is offline
Default Re: through hull drain tubes in the floor
My 18 has no scuppers except the 2 in the motor well. The plastic ones behind the baitwell have been filled with 5200 and the hoses/tubes and wherever they went are gone. I have toyed with the idea of cutting flappers in the side of the hull at the floor to have some drainage, but as low as the thing sits in the back they would probably only work when running. I can't imagine scuppers that run through the bottom work all that well either.
Eric
Old 09-29-2009, 10:27 AM
Default Re: thru hull drain tubes in the floor
. . . I can't imagine scuppers that run through the bottom work all that well either. Eric
That's because your missing one small but important detail. There are small wedges attached to the hull just in front of the scupper tubes which create SIGNIFICANT suction. It pulls the water out much faster than just depending on gravity!
I think I had temporarily removed them for better access when flaring the end of tube, so that's why you didn't see them in photos in my old post.
Also, you don't necessarily have to buy an expensive flaring tool. I used some threaded rod, nuts & washers and some tapered sockets I had to get the flare started, then finished with ball peen hammer. Maybe not as pretty as using a tool, but it worked! One problem with those plastic tubes is that they will eventually crack if enough UV gets to them.
Old 09-29-2009, 11:14 AM
I had replaced these on an older Whaler I had. A tow ball works great also. I had to "anneal" the brass tube by torch heating and quench in water usually twice. This prevents splitting when flaring.
Old 09-29-2009, 11:48 AM
I have no evidence on my boat that anything ever went through the bottom of the hull except the drain for the baitwell. I will search harder i guess.
Eric
Old 09-29-2009, 06:31 PM
The thru-the-bottom scuppers may have been unique to the Potter models, about 1970-79. Not sure of configuration post-Potter.
Old 09-29-2009, 10:19 PM
mine is a 79. i know it had them at one time because the plastic thru deck fittings are ther but have no tubes or hoses attached and the fittings have been filled with 5200
Old 10-02-2009, 09:01 PM
Gary Hill Gary Hill is offline
FELLOW SHIP and you other people that have changed the deck drains come aboard with some help!
GARY
76 SEACRAFT CC INBOARD
if your floor drains are like mine, it was pretty easy to get them out and put new ones back in. i tried to use PVC but didnt like it. i would have had to get new plugs and stuff. so i went ahead with the brass and epoxy and have had no problems or leaks yet. thats been probably 1.5 years ago.
Old 09-29-2009, 11:23 PM
avian22 avian22 is offline
Bush I'm going to have to start paying you for ideas. I would have never thought I could taper the tubes like the way you described. Definitely hit you up when I attempt that. I have to watch a couple of old mcgyver episodes to gain some confidence first. LOL
In reference to Greno's qoute. I do have a major problem when those floor drains are unpluged. If your maintaining your station and you walk to one side of the boat the drain hole in the floor drops below the water line and begins to pour onto the deck. I always thought that was kind of a weird reaction if they weren't meant to be plugged all the time.
Old 09-29-2009, 11:25 PM
has anyone else had the flooding problem with the drain dropping below the water line when you walk to one side of the boat?
