"marine" bondo ? hmmmmmm
Marine Bondo is just a thickened fiberglass resin to which you add catalyst. It is not their regular plastic mender. It just has the name we have learned to distrust on the water.
I used it on plugging bolt holes where my old kicker bracket used to be. It looks like regular fiberglass resin, i.e.; transparent light yellow color. I bought a pint of it because West Marine here was actually out of MarineTex polyester mender. Worked just fine.
small screw repairs and such I have just filled with 5200 and said good enough
with a small tube of it just press it into the hole let a small amount over flow on the top side, when it dries just trim flush with a razor blade, looks OK to me |
![]() Quote:
If I told him to get some P-78 High-Heat Resist Filler Fairing Compound (Polyester Resin)from Adtech Plastic Systems he most likely would say "What" ![]()
sounds good, how do you guys finish it? Do you mix up a little gel coat and then top off the marine bondo or 5200 to try to make it look nice?
1988 18' Seacraft 1988 Mercury 115 |
![]() Quote:
if the holes are larger bolt holes then it will not look so good then you open a new can of worms with either paint or gel coat |
yeah, I have everything from small screws to large 1/8" and 1/4" bolt holes....
GRRRR
Just mix up some West Systems resin and hardener with a little thickening fiber and leave it 1/8 shy and finish with some gelcoat. Matching the color is the hardest part.
