That's a good idea Sam although I don't mind a little slime on my sausage.
Strick, Gramps used to have a big steel cooler in the Salmon charter days. I usually catch and release unless I'm hungry. You guys have some great ideas! |
Fish/dive gear storage is about the only thing this boat is short of.
The previous owner of mine had a 6 ft insulated fish box built that sat on the transom (see my photobucket page for pics) I planned to put a teak platform and kicker behind it until I started calculating how much all that would weigh. Plan B: had an aluminum box/platform built. I'll use it for light dive gear storage, but it could easily be a fish box. Will post pics when I finally get everything mounted. |
Strick
I noticed in Connors pics, his fuel tank hatch is roughly half the size of ours. Ours goes right to the stepdown. I assume yours was the same as Connors before it was cut out. I guess the difference is that we have one tank and you guys have or had 2 and I guess they slid the one under first before installing the 2nd. That being said, I know you have to rebuild yours and wanted to give you my thoughts. Ours is loosening up at the joint and is a little spongy where it meets the stepdown. It gets a lot of traffic and I think there should be at least 1' of solid floor at the top of the step. Even better if you have more, like Connors. My opinion is based on the fact that the hatch hasn't really deteriorated much in the last 15 years since she's been under my care and knowing how much traffic she saw in the charter days so it was a little spongy 15 years ago. The rest of the hatch is solid although dipping a little in the middle. You'll notice I use the words "a little" a lot. My theory is, when I start to use the words "a lot" a lot, thats when the major resto will begin. |
My desk top computer is down so it may be a few days before I'm able to post any pictures showing what I have done with the floor and deck hatch on the 25 seafari. It has more support then the original design and will not ever sag or get spongy...ever again
![]() strick
Hopefully this will work as I'm posting from my lap top wireless modem. Some more shots showing the area were I reinforced the deck and area were the big hatch will sit. In the original design the deck sits on top of two stringers that sit about 5 foot six inches apart. The hatch that accesses the fuel cell sits on a lip in the middle of this large span.
Although the deck on this boat is solid the one on my other 25 seafari is spongy in this area because of a lack of support under the deck and water intrusion in the deck core. In the pictures below you can see were I've added a 1 1/8 plywood encapsulated in glass and bonded to the hull. Both the deck and the new hatch will sit on these supports offering more support to the deck and hatch as well. Mold for fuel hatch. This hatch is going to be about 6.5 feet long. Hooking up the sander to the shop vac makes sanding much more enjoyable Adding flange to the mold. The base of the mold is 1/2 inch plywood sanded on one side. I did not use mdf because it is too flexible to for such a large hatch. Mold ready for lay up. There is 4 coats wax and 6 coats PVA over this. A shot showing the scuppers that drain out the side of the 25 seafari Mounting block for the seacock First coat of Gel coat for the engine compartment and bilge Back to the fuel hatch... two coats of duratec Two layers of heavy mat and one payer of 1708 Cabosil and then 1/2 inch wood coring More cabosil fills the gaps between the squares More 1708 over the squares trimmed and ready to be removed from the mold Test fit I left it high on purpose so I can later trim it flush. Shaquille O'Neal can jump up and down on this hatch working on the base for the fuel tank. It will be glassed on both the top and underside then bonded with cabosil and glassed to the hull. I managed to get the cap primed yesterday evening just before dark. strick
OR...you could do THAT. I wasn't even thinking that you could do it that way. That's going to turn out sweet.
That surely covers what I was trying to convey to you about the top of the step needing to be solid. You may have read what I said on Connors thread about the drainage in the stepdown. I was just curious as to what you had planned for yours. Brandon BTW I wasn't rushing you on my last post but I'm sure Pavlov's dog is happy now ![]() |
Hey Strick,
I like your thru-hull mounting block work, very neat and clean. Is it for the DS-ducer? I've been led to believe that it might be worth the extra effort to set it verticle to the waterline with a counter cut set of wedge blocks mounted one on both side of the hull to offset the deadrise. Just asking.
Getting home is more important than getting there! Plan accordingly! |
Strick,
Great work! I found the thread on your rebuild from 2 years ago last fall. Spent a crazy amount of time reading all 20 pages. Learned a lot. And I just found your new project last night. We're about 45 minutes from where you are and we boat in the Delta also. A couple of questions, if I may. 1. Back in page 4 in your post 81730, you show both the fuel hatch and the forward hatch. Why does the fuel hatch have all of the little wood squares, and the forward hatch doesn't? And why did you cut the wood into little pieces instead of leaving as one large piece of wood? 2. Where did you learn how to make molds out of MDF? Are there any good books on the methods you are using making custom marine parts out of fiberglass? I'm looking forward to more pictures and posts on your project. Titaniumboy |
Looking good as always.
