Hi Jim,
Stringers and deck seem to be in great condition. What i assume to be the original non-skid is in great condition also. Worst spot is gunnel/rubrail on port side is thin. Personally i would beef up/back up under the gunnels around the rod holders anyhow. Looked closer at the trailer no rot, just minor surface rust. The tires have dry rot, might not be an issue with such a light load but might be safe to replace. Bearing/seals should be fine, bearing buddies and seals are not leaking on the inside. Best to pic up a spare hub assembly or two and roll on ... depends what your plans are for the trailer. I could also trailer some of the way if that helps. I will send you a PM with my cell if still interested ... - Nick |
