![]() Quote:
If you have a decent ramp to launch your boat then a float on is the way to go. Rollers can be a pain in the butt.
![]() Quote:
![]() ![]() My tandem axle Continental has all stainless hardware galvanized axles, hubs and lug nuts. Stainless Buddy Bearings. 7 Grease-able 12 inch Stoltz Keel rollers 8 Grease-able 4 inch Stoltz donut rollers 10,000 lb. Power Winch 3/16 inch stainless cable. Stainless lanyard cable to operate winch "solo" from 2 X 12 inch rough sawn Cedar walkboard to the back of the trailer!!! About the greasable shafts, 5/8 inch galvanized bolts that are 14 inches long. (excess cut off after head of bolt welded to the galvanized roller frames) Drilled approx 5 inches into the head of the bolt then tapped for a zirc fitting.... This trailer works on any ramp anywhere. I can launch and load by myself anytime!! If you take care of it, It will take care of you! ![]() ![]() ![]() ![]() ![]() ![]() Even works as a park bench for Doodlebug, Skipper-T & Bushwacker.... ![]() ![]() ![]() ![]() Do not get me wrong, I also have Float-On trailers as well. But for me, The roller trailer is my favorite. Oh yeah, This trailer is a 1980 and still going strong.. See ya, Ken
See ya, Ken © |
![]() Quote:
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET |
i have 4 "service" trailers,all roller.all urethane rollers too,never a problem with rollers,upkeep is minimal,give 'em a squirt with the hose...bearings hold up longer,due to the fact,the wheels are never submerged.bunk trailers in an area with a good tide swing,make it just about impossible to load and unload in a low tide.also,the aluminum trailers,these will float.personally,i would never own,nor do i reccomend bunk style trailers to customers...
do not let common sense get in your way |
My 'new to me' trailer is aluminum "Magic Loader." I think it came with the SC.
If your ramp is in a strong tidal area or a river - forget about an aluminum unless you outfit it with weights. I found out the hard way the trailer floats! Royal pain if your by yourself and the trailer starts heading out to sea with the tide.
1988 18' Seacraft 1988 Mercury 115 |
