Even though it seems like progress is never very close I think I can see the light at the end of the tunnel.
For the past few months I have been working on the top cap of the boat. Under normal circumstance's this would not be too difficult. However do to the amount of crazing and spider cracks the project has become monumental. Grinding out all the stress and spiders was out of the question. So I decided to lay glass over the entire cap. If it was one flat area that would of been easy. But as you can see by the pictures there are a lot of curves and skinny toe rails. What I did was use 4 oz. cloth and epoxy resin. This was the only weight that would contour to the tight bends. Hopefully this will be heavy enough to keep the cracks from returning. This type of spider on the top gunnel was cause by down riggers with no backing. Ugh. ![]() Crazing and impact. ![]() ![]() More Crazing ![]() ![]() I think you can get the idea ![]() Glass layup ![]() This is the part that you had to babysit the curves and make sure there where no voids. The front deck lay up easy... ![]() After all lay up is done then I used a product called ProSeal EZ Coating System. This is a two part component epoxy,a pre filled system for filling the weave in glass cloth. It is applied by roller and brush. I call it a liquid fairing compound. ![]() ![]() Some Zebra strips...and now I will be sanding for the next week or two [img]/forum/images/graemlins/tongue.gif[/img] ![]() The good thing is the hull above the water line has very little in abuse and that should be a snap to get that done. More to come as soon as I get it done ![]()
Ouch thats a lot of work Terry but I think you made the right move by covering it.....you would have never been able to get it fair with all that grinding.
Terry-Great job. Did you lay glass over the entire bottom of the hull? Did the hull sand blasting open up enough voids and pores to require the added glass? I have been reading about re-glassing hulls below the waterline due to damage and your work on both the top side and bottom with glass fix those concerns without grinding those spider cracks and voids for the rest of your life! Thanks for the info..........
Snookerd |
Snooker, I did not cover the bottom. The bottom faired out real well after the sand blast. The only place that I glassed was in some of steps areas. There was a fair amount of cracks, that where caused when the previous owner removed the center bulk head to install a bigger tank. This put stress on the stringers and must of caused a lot of flexing.
Strick there would not of been enough time in my life to grind out every crack. So this hopefully should take care of that decision.
Well I figure I was getting so good at covering all my crazed and cracked parts I might as well get the last one done. [img]/forum/images/graemlins/tongue.gif[/img]
The engine box was a mess just like the top cap. The only difference a lot less curves. So glassing over it was a snap. I think from last weeks post you get the picture ![]() ![]() ![]() This boat was built in 1964 and it has a Diamond on the box. Does anyone know when they went to the Hull Profile on the box? All patched up and covered with 4 oz. glass. ![]() Covered with Liquid Fairing Compound and ready for sanding. ![]() Flip this dog over and grind out the old coring (actually this was done first). ![]() Wooden Pads for the box hinges. ![]() Epoxy in the Plascore coring. ![]() 1708 trial fit and then epoxy in. Let me tell you this thing is now sturdy. No more stress cracks that is for sure. ![]() ![]() Still sanding on the top cap. However progress is being made. My goal is to have the top cap engine box and hull ready for priming by June. That is it for this week ![]()
Well the better half finally pulled a Trump Card.
No more Seacraft work until I do some house maintenance. So last week end when the heat index was 105 I was hanging lattice on the under part of the house (no tears from the wife, she said I would be sanding on the boat in the same heat) [img]/forum/images/graemlins/tongue.gif[/img] However I did manage to get all the fairing done on the top side. Let me tell you sanding epoxy filler is not the same as sanding primer. The sad part is I will be shooting sanding primer in the next few weeks and will have to do it all over again. But hey we are having fun RIGHT! Lattice Job. First Level is 15' Above Ground ![]() Front Deck...All dark spots are the high areas that have been sanded down. ![]() Transom ![]() Port Side ![]() Starboard side. If you look real close you will see some shiny spots. These are the low areas, that should fill in with the sanding primer. ![]() Tools of the Trade ![]() I know these pictures are not earth shattering, but some one got to see them ![]()
I'll look at all the pictures you want to post.
1975 SF18/ 2002 DF140 1972 15' MonArk/ 1972 Merc 50 http://i833.photobucket.com/albums/z...photos/SC3.jpg |
Gotta keep the the ladies happy...give a little and usually they give 200% back. They are very tolerant of our hobbies. Keep up the good work....at home and on the boat.
![]() strick :
