Old 06-09-2010, 08:48 AM
Default Re: fuel tank
Does anyone remember the thread that included this method.
FellowShip
Just for the Grins
Official Antique Classic SeaCraft Owner
Old 06-09-2010, 04:34 PM
gss036 gss036 is offline
I removed the fuel sending unit and was able to get a hook on a piece of metal turned sideways and used a come-along from a rafter in my pole barn, worked great for me.
Gary
Old 06-09-2010, 07:32 PM
Someone used a pressure washer to blast the foam out. Thought that was a good idea, if a bit messy.
Old 06-09-2010, 08:39 PM
I remember!! "Lt Dan" used an electric chain saw to remove his tank. I think "John R" wrote a limerick about the ordeal?
Ha Ha Enjoy the read
Lt Dan / Chain Saw
Old 06-09-2010, 10:01 PM
tri5 tri5 is offline
tanxs guys like the pipe in the sender hole but think ill use the excavator to lift the tank. far as sawing or blasting there less than 1/4 of an inch between the stringers.hope it just brake loose.
Old 06-09-2010, 11:35 PM
...but think ill use the excavator to lift the tank. ...hope it just brake loose.
I used an Excavator too, after I cut through the foam w/ a skinny hand saw.
Check out the hole about the size of a quarter on the side where it was "foamed" in........bad idea.
Old 06-11-2010, 07:57 PM
tank is out luckey me not much foam and verry dry. took 3hr and 4 beers but w/ little triming and pry she pop right out
