Old 07-14-2010, 04:53 PM
bridgeman bridgeman is offline
Default Re: Post 1980 Seacrafts
Very happy with my 81
Old 07-14-2010, 06:45 PM
The early 80's boats built by CSY were good boats, I think your good all the way to 85 ???
Old 07-14-2010, 10:30 PM
BigLew BigLew is offline
I've got a '85 Scepter and no complaints except a weathered gelcoat!
Plan accordingly!
Old 07-15-2010, 12:59 PM
The early '80s 23' boats were made by CSY, the 20s were made by Seacraft Industries. I've heard CSY used Potter's molds.
I have an '83 20SF. At 20'-4", it is 8" longer than a Potter 20 SF. It has a very slight hook in the rear of the hull, and I think that makes it a little slower than a Potter 20 SF with the same horsepower, but the ride is Seacraft all the way. I don't know if the hook is unique to my hull, or typical of all the Seacraft Industries 20 SFs. It's slight enough that you need a 4' straight edge to see it. Other than that, I would say the quality is similar to a Potter. The hook, if typical, may have been introduced intentionally to keep the bow down at higher speeds. Just a guess.
Dave
Blue Heron Boat Works
Old 07-15-2010, 07:27 PM
castalot castalot is offline
i'm happy with my 86 23' cc 87 is when tracker bought the line and who knows what happened after that but most brands got "cheaper" in the late 80's and early 90's
but like anything that is older it depends on how it was cared for and what inprovements have been made
Old 07-15-2010, 10:25 PM
my 23 is an 87. i have not run it but im going to rebuild it. ive taken it apart a little bit and ill tell you there is alot of glass in that boat still. i dont see anything seperating structually yet so it cant be that bad.
Old 07-16-2010, 06:55 PM
hfrench hfrench is offline
I have an 1988 18' - no issues what so ever.
Old 07-17-2010, 01:18 AM
In late 1987, we got in an '87 Tracker SeaCraft 23 WA at Lake Worth Yachting Center, where the transom had been severely damaged in a rear-end collision while being trailered. As part of the repair, the entire transom was removed. I was then shocked to learn that the stringers in that boat were fiberglass-encapsulated plywood, unlike Potter hulls. And though the hull was just one year old, the plywood was already wet and separating inside the stringer.
Fr. Frank says:
Currently without a SeaCraft
Old 07-17-2010, 02:14 PM
i guess i will be drilling a few sample holes in my stringers.
Old 07-17-2010, 07:51 PM
The WA looks to be an unknown design. I will not defend Tracker`s riggers or cheap hardware. I had a slight delam of about 1 1/2 ft by 4 " of the top layer of the inside of my port stringer , but they are the big box foam stringers of the `72/73 design change on my `89 20.
Did tracker own another boat co. that made the WA and just rebadge it? Ah, the onion.
Blue Heron, where is the hook in your hull?
CSY`s may have been the heaviest, but I bet the Moesly`s were the most consistent.
Cheers,
GFS
