After Moving Way up North (Melbourne,Fl) I had 50 Gal. of gas for about 2+ years. It had Oil, Additive etc mixed. It burned,smelled good (No Varnish) etc.Couldn't find a way or Place to get rid of it.. Placed a ad on Craigslist & explained everything, Fellow showed up w/ containers for Half next few days came & got the Rest. He said the size of His Tank Mixed He didn't care.. Easiest I've found Just let em' Know it is Old. (Was Not Ethanol). Good Luck!
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Where r u locate in Eastern NC...I mite can be of assistance! I've got an electric fuel pump rigged up for this purpose.
Keith Willis 25ft Downeaster Pilothouse Ford F350 Super Duty SRW 1977 SeaCraft Sceptre- SOLD |
WILSON , I have a new twist to the story today . If I can rem. how to post a pic , you won't believe what I found when I removed the filter late last night. Yhe top of the filter is covered in what looks like uncooked grits . white , tan dark brown perfectly dryed crusty BS
I have never seen anything like it.!!! |
I used up some 2 year old gas in my ole Dodge truck.
Dumped 6 gallons at time in when I would go to fill up.. It even had TCW 2 or 3 in it... Trucks valves had never been cleaner! ![]() This was many years ago when the truck had 50,000 miles on it. Today she has 285,000 and still going strong. See ya, Ken
See ya, Ken © |
WWP2, if I were u, I'd invest in a cheap electric fuel pump...pump it out and run 5-6 gallons in my truck...thats what I normally do with old fuel.....mixing it with a fresh tank. If you dont want to do that...I'll run up that way sometime and pump it out and burn it for ya! Let me know what you think.
Previous to my restoration,my Tsunami sat in a field for six years with about 45 gallons of gas in the tank
We siphoned it out and guys at work put it in their pickup trucks and tractors. None of them had any problems with it.They were more than happy to get free gasoline. I,on the other hand didn't dare try it.I was just happy to get rid of it.
I'm the poster to this thread originally .An update , I drained the gas and it looked and smelled just like some fresh gas that I had. I mixed about 10 gals in my truck tank with 7 gals of gas already in the truck .What a F - up
The truck cranked and drove for about 2 mins . It spits , jumps ,coughs and every other noise you can think of.It will not continue to run when you put it in gear .I am an Idiot , my wife laughs at me , This really sucks |
Bummer! How many more gallons will your tank hold? Maybe change your inline fuel filter a time or 2 (I assume truck has one) Then either drain the tank or top it off with high octane or pour in some octane booster). Hopefully the sediment in the old gas just clogged up the little filter and it clears up some by changing the filter.
10:7 bad gasoline ratio was maybe a little extreme...hope it gets right for you. Good luck.
![]() Quote:
My grandfather said he learned that trick back in the early days of WWII when the gas being distributed to civilians in the Keys was often the old military stock-piled stuff, which the Navy got rid of in favor of the new higher-octane gas. JFTR, I burned the rest of that old gas without a hiccup afterwards. (Of course, 97% pure grain alcohol - that's ethanol based, not isopropyl which may be methanol - could be purchased from the Rite-Aid drugstore back then for only 70 cents a gallon)
