Seen PVC board mentioned a couple of times lately. What is it and where do you get it? Also is it like starboard?
![]() Quote:
Rigid Polyvinyl Chloride (PVC) board It has excellent corrosion and weather resistance. As well as a high strength-to-weight ratio and is good electrical and thermal insulator as it is fire retardant and self-extinguishing. It has many usages. PVC foam board has many of the same characteristics of wood that it easily sawed, bonded, nailed, painted,caulk sealed, joint and hot moulding. I glue mine with the same PVC pipe cement. Can't do this with starboard. Some Sign shops carry it.
Thanks that helps a lot. I have a friend in a sign shop which will give me access.
Can I simply glue the foam board to the transom and then mount the pump on that? Or do I have to seal up the foam with fiberglass or epoxy or something? Does it absorb water?
