Old 09-25-2010, 03:26 PM
castalot castalot is offline
Default Re: 25 Seafari...55mph
i dont have a 25 but i will give you a quick answer
no a 7000 "gross" trailer won't be enought the trailer might be 1500 leaving you 5500 of boat
i have a 7500 gross for my 23 and it's rated for 5200 load
Old 09-25-2010, 04:35 PM
cdavisdb cdavisdb is offline
My Seafari and my old Seabird weigh very close to the same, hull only about 3000 lb. The Seafari can't be more than a few hundred lbs more than the Seabird, even fully loaded. I put the Seafari on my old aluminum Owens float-on trailer, 7000lb capacity, and it tows perfect, you hardly know its back there. No noticeable difference in the tires or how the two boats towed. I figure boat, trailer, fuel, ice, gear, etc is very close to 7000 lb. Fully loaded for a long trip might be a little bit more. Note: a steel trailer weighs a lot more and leaves less for the boat.
Connor
