Old 10-23-2010, 06:40 PM
Cheg Cheg is offline
Default Re: 23 CC rebuild - shine
If I could jump in here with a question. Fellowship, where is the water line in relation to the scuppers?
Old 10-24-2010, 08:43 AM
Hi Cheg:
“On my boat”, taking under consideration all I said about what I did moving things forward my water line is approx ½” down from the top 90 degree corner edge of my trim tab bracket that screws into the transom.
With a single engine on the transom or a bracket with flotation for twins it should be somewhere like mine.
With a twin engine configuration the 23 will squat more and that water line would be higher on the transom. That’s why “for me” if I were to ever go with twin configuration I would want to raise the deck.
The SeaCraft design is a VERITABLE Deadrise hull and it sits in the water different that a straight 24 degree deadrise hull does.
My boat sits on a bunk type trailer. The bow of my boat does not rest on the bow side of my bunks. There is a gap of approx 1-2” between the boat hull and the bunks. If this is true on my trailer it is also true sitting in the water.
This is part of the reason why moving things forward on SeaCrafts is important. It helps in the bow to stern teeter totter effect to be reduced to a minimum. This needs to be factored into you over all re building plan. If not, your SeaCraft might look Great, it might right grate in ruff seas but it will effect you sitting at the dock or drifting around in open seas.
This is why many guys want to close off the transom and put a bracket on But if you add too much weight then the next issue is all the scupper threads on this sight.
Think About It.
FellowShip
Just for the Grins
Official 23’ SF Antique Classic SeaCraft Owner
Old 10-24-2010, 01:40 PM
shine shine is offline
Moderator
Thank you to everyone for the data. I have enough information now to plan the boat.
I do not want to redesign the boat, although I am able to do this - redraw to boat from scratch and redesign the weights. It would mean making a model and I fiddle with weights and spit new out hydrostatics . One of the appeals of choosing a re-build is that all that work is done, all I need is original locations and weights and I can move everything around and maintain the CG and waterline the designer had in mind. Far be it for me to change a well balanced design
Also, the fact that this forum exists was a major consideration in choosing a seacraft to rebuild. Without a source like this forum, I would have to do a lot more work
Im getting very excited to use this boat, Im hoping to have it ready for power by May.
Old 10-24-2010, 09:55 PM
Great info. Thanks.
Old 10-25-2010, 03:05 AM
If it were me starting with what you have. Here is what I would do:
1. Core the sides (it will be bullet proof)
2. Put the consel were it was intended by the factory or maybe a just a hair forward. Remember every inch you move the consel forward equal's more pounding on your feet.
3. Move the fuel tank forward so that the front of it is even with the front of the consel.
4. batteries in the consel
5. Build your new deck and bond it to the top of the stringers. Since your stringers have already been raised 2 inches there should be no need to raise it any more. I'm not sure about your year boat but the boats built in the 70's were self bailing at the original height.
6. build the livewell above deck just behind the leaning post.
Again I'm not sure about the 80's boats but the cockpit sole on the 70's was bonded to the top's of the stringers and it should have been no dead air between the stringers and the bottom of the sole. But then again that may vary depending on if a boat was built on a Monday of a Friday
On my 75 it was a tight bond:
PS do away with the flat butt and put a nice arched transom on that boat if you are going to go with a bracket
Old 10-28-2010, 12:10 PM
Moderator
additional layer of 3/4" ply epoxied into place, tabbing of 3 layers of tape are in, now we are cutting the wide biax for the new inside skin. Found a 109 gallon tank that will work, have not bought it yet, still want to find two tanks that will fit (without having to pay $500+ for each one !)
Old 11-08-2010, 03:33 PM
Moderator
reinforcing stringers (building thickness to 3/16" minimum everywhere). what you see on the stringers in these shots is 3 layers of 1810, all wet on wet. Will do other side this afternoon. I am going to add a couple layers of tabbing also (stringers to hull).
We still have two more layers of 1810 to go on transom. 8O
Old 11-19-2012, 09:20 PM
ledslinger ledslinger is offline
Shine, In my case, a 79 jackshafted diesel that has been converted to a closed transom bracketed outboard) I have no reference to what existed before and where the cg of the boat should be.
My question is how did you design your boat and where did you find the information to arrive at your calculations?
"Something is happening but i don't know what it is"......R.A. Zimmerman "Ballad of a Thin Man"
Old 11-21-2012, 10:25 AM
Moderator
Lets start a new thread and we can discuss it
I will get it going
Old 11-24-2012, 01:28 PM
Shine your boat is gorgeous bro! I just bought a 23 1986, has new transom will be adding a bracket and need to make a mold for the top of the transom like you did, your thread is very helpful!
