Old 12-01-2010, 11:03 PM
lost2a6 lost2a6 is offline
Default Re: Taking off outdrive
no need to pull the wheel if it has a rubber hub-freezing temps will never damage it...age and impact will tear it up,cold weather isn't a factor...just be sure to pull the wheel once a season-lube splines and rinstall
side note:
use no grease with mettalic compounds-especially "never sieze" you can create a galvanic reaction...
Not what my prop guy says. http://www.southeasternprop.com/index.htm He said that some times once the rubber shrinks due to the cold, that it will not expand back to its original diameter therefore resulting in a spun hub. I can't prove if he's right or wrong being as it seldom stays below freezing very long down here. Anyone want to put their prop in the freezer for several days to test his theory?
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
