Old 01-09-2011, 03:05 PM
pelican pelican is offline
Default Re: Repower for 23' I/O
I run mine with the alpha and a thru hull(sea strainer) to the raw water pump (bravo engine).
that's ok...but...you need to instal the [censored] interupt on the new engine.also,you need to install the block off for the cooling water tube-from the swivel assembly,to the engine.you're also gonna need to remove the water pump impeller from the drive...
