Old 05-21-2011, 06:40 PM
jwclbi jwclbi is offline
Default Re: 225 merc question
Thanks Doodlebug, I will check it out, that was a new trim motor 2 years ago. My concern was the rust where that wire bolts on the at the bottom of the wire. would that have something to with it. Everything else is very clean and tight, but I will double check. Any more info would be great, thanks,
Old 06-10-2011, 05:24 PM
Well after a lot work I finally had time look at this issue again. After checking the ground for the relays and seeing it was really clean I still took it off and cleaned. Also was able to free and clean the nut that holds the bottom of stainless wire that heats up and smokes during use. And after all that the stainless wire still heats up, smokes, and after a cycle of up and down stops all together. Anybody have any other thoughts?? Almost thinking something in trim motor as mine is a 20" shaft O/B and trim motor gets very wet??
Old 06-14-2011, 02:13 PM
Disassembled trim motor and found water and metal shavings. Anybody know someone in south nj good at rebuilding these things? This last one wasnt done so great. Thanks
Old 06-21-2011, 10:02 PM
Got new trim motor, installed it, everything works fine. 2 rebuilds later you think i would have learned.
