Old 05-29-2011, 08:07 AM
CDLongJr CDLongJr is offline
Default Re: Can't get lower units off
Yes, you go down thru the hole on the rear. That bolt has been removed.
Lifted engine back up, found the bolt ya'll were talking about. Lower unit is off. Thanks a million!!!
The Ole Fart
1986 23' Walkaround w/cuddy, Twin 135s
Old 05-29-2011, 09:15 AM
Ok, repairs made, now it won't go back together. Lacks several inches from going up. I turn the prop, thinking the driveshaft splines aren't lined up, but when I turn the prop, the driveshaft doesn't turn, (althought I don't know how or why they would have turned).
The Ole Fart
Old 05-30-2011, 12:03 PM
did you remove it when it was in gear??
Old 05-30-2011, 02:32 PM
put vice grips on the shift shaft (on the lower unit) and shift the lower . . . clockwise is forward, counter clockwise is reverse. Once lower unit in gear . . . just make sure it matches your the throttle position (forward or reverse) Drive shaft spins clockwise always.
