Old 09-25-2011, 09:56 AM
Originally Posted by Max_Florida View Post
Are you referring to a synthetic like divinycell?
I had considered it, but balsa properly taken care of should last a good while... hopefully by then I'll win the lotto and be able to completely restore the boat.
I'm going to do the project today, I'll sand it tomorrow after it cures, slap a coat of paint on it to protect the epoxy(I plan on painting the whole boat after I redo the transom this winter) and then install all of the anchor hardware on Tuesday morning.
If everything goes according to plan I'll be putting her into the water on Tuesday morning. I'll keep you guys updated and post some pics. I appreciate the advice.
I like the idea of balsa most everywhere else, but I would consider the area under a cleat to be similar in stress to the transom. So something a bit more robust. I don't like plywood in general, but right under the cleat might be good. I am not sure if there are different strengths or densities of divinycell, but if there are, I would get one of the stronger/higher density versions for the ~square foot or do under the cleat. Or put load spreaders between the cleat and cap. Basically a construct a reinforcing plate so that the loads on the cleat dont make it locally break the fiberglass under the edge of the cleat "feet". I suppose THOSE load spreaders could be starboard and added after the fact and be beveled to look pretty nice.
Old 09-26-2011, 09:38 AM
Max_Florida Max_Florida is offline
Well, I called every place that I could find on Google in my area and none of them carry divinycell or balsa in 3/8". Looks like I'm going to have to order it from somewhere or drive out of my area to pick it up. Anyone know a place in SW Florida that carries, or can order, core materials?
As far as extra support for the bow area(cleat, anchor roller, etc.) I was going to mount epoxy coated plywood underneath the bow cap area. Similar to how Dennis did it: http://www.classicseacraft.com/commu...anchor+bracket
Old 09-26-2011, 07:11 PM
Ended up ordering a 3/8" piece of scored divinycell.
I also decided to switch from epoxy to vinylester resin for this project.
The plan has evolved to the following:
I'll sand down everything and bevel out the existing fiberglass 12:1 along all the edges.
I'll patch any holes in the bottom skin, possibly even laminate a fresh layer or two of 6oz depending how flimsy it feels after I sand it. I'll let all that dry and then re-prep the area.
I'll laminate a layer of 6oz cloth on the bottom of the divinycell and then while it's still tacky glue it down with a layer of Fasco 110 applied with a caulking tube. I'll weight it down on the top overnight while it dries.
The next day I'll trowl down cabosil into the scoring and along the edges so that its nice and smooth. Then I'll laminate 3-4 layers of 1708. I'll let that dry overnight.
Then I'll put a layer of fairing compound over the whole thing, let that dry, sand it down and paint it. At this point I will also mount plywood on the underside of the bow area to support the anchor hardware.
I'm not sure what else to use to cover the fiberglass itself, I am eventually going to paint the boat so doing a gelcoat didn't seem like the right thing to do.
I'll post pics as I make progress.
Old 09-27-2011, 08:44 AM
I order to make it look good you should fair it out with fairing compound and then throw a cheap coat of paint over it.
I don't know where you are getting your supplies out, but since you are in sw fla. check out
fiberglassservices.com
Old 09-27-2011, 10:28 PM
I like the idea of balsa most everywhere else, but I would consider the area under a cleat to be similar in stress to the transom. . .
There is no core under the bow cleats. It's solid glass, ~ 1/4" thick. I added 1/2" thick plywood under those cleats and then a couple layers of 5/16 plywood reinforcement, approx. 15x15 under bow area including under the cleats when I added anchor bracket.
Old 09-28-2011, 07:03 AM
That would make sense, structurally. I can't tell what is going on in the picture supplied- he mentioned rot- and it looked like there was wood in there? Or is that some sort of delamination?
Old 09-28-2011, 05:39 PM
Default Core
There was a 3/8" balsa core between two layers of glass which extended from 4-5" below the hatch to 2-3" from the hull. There was significant rot(some areas were completely gone).
I think after I get the new core in I will build up some reinforcement like Dennis did.
I also am going to coat the inside of any holes I cut with epoxy. I don't think the divinycell, being a synthetic, will be affected by water, but I still don't want any getting in.
