![]() Quote:
strick |
Here's a little tip for you:
When mounting ant's, mast, rigger bases, etc. Drill and tap through the top, core and all, tighten down the bolts, then put your washer and backing nut on. Properly bedded of course! Get much better holding power that way, never seen one pull out or compress. Strick is God! :-) |
Sorry i thought this was going to be a pilothouse, sounds like its going fiberglass top with the aluminum pipes supporting.
![]() Quote:
Yes it is Mike. You may want to watch the thread, you never know, you might want to see what boat it's gonna end up on???? ![]()
http://i224.photobucket.com/albums/d...t/0a21e0b9.jpg |
Oh don't worry im watching
Pretty excited about the top Mike. So far I have rigged it for great lakes fishing, barely. Soooo expensive to rig. Other plans are: rocket launcher, kicker motor, auto pilot, radar, etc.
73 tsunami |
Wow its hard to believe how that boat has progressed over the years from when i found it. When i bought this boat it was just neglected and not taken care of. And now look at it, being well cared for and is in a class of its own. Thats what these CSC's are all about. (Old Entourage that is)
![]() Quote:
that's an "old school" technique - drill a 3/16 hole,and run a 1/4 - 20 machine screw in - no need to "tap" - again,old school technique - ocean yacht used this alot...
do not let common sense get in your way |
