Old 07-24-2012, 06:07 PM
thedink9 thedink9 is offline
Hi Smith Can you provide a few more details on the rebuild, such as did you rebuild the transom and if so what method / materials did you use. Did you spray or roll and tip the paint and what type of material did you use. Was the tank replaced, if so how many gallons does it now hold? Do you have any pictures of the rebuild in process? That would help any more questions that I have. Thanks Rich
Old 07-26-2012, 01:17 PM
smith401 smith401 is offline
Default Refit
Good day,
To all that are wondering:
-Stringers were replaced
-New fuel tank, made by New wave fabrication- 55gal
-New deck
-Repainted/ repaired CC
-New leaning post- made by Blue water towers, with after flood light, nav lights
-Leaning Post
-New paint inside and out, Sprayed outside with Awlgrip-fighting lady yellow, Inside Sprayed matterhorn white and rolled floor with course nonskid
-Evinrude 150hp- Rebuilt By Lighting Marine
- Rewired with new bus bars, new fuse block, new switches, new gauges, new pumps
-4 30degree rod holders in gunnel
