Old 03-12-2013, 06:55 AM
pelican pelican is offline
Originally Posted by Rondo View Post
If you're using plywood with polyester resin for your project, prime the plywood with resin thinned 20-25% with styrene and an appropriate amount of hardener ( Make sure that the plywood is fully aired so that any residual chemicals evaporate off the surface.) Give it a couple of coats and let it set in and dry. Your glasswork will then adhere to the plywood with a much stronger bond.
you can try that,but...
polyester bsed resins,contrary to popular belief are not the best choice when working with wood
epoxy is allways the best choice...
a smart choice is to use composites - a quality composite like penske/coosa board will give you a core that will last,versus wood.composites,a quality composite is allways a better choice...
