Thread Tools | Search this Thread | Display Modes |
I will add two layers of of 1808 over the 3 layers of mat to add a good bit more of strength. After getting this far and hot coating the matted layers in the 95 degree heat in direct sunlight. I had to work faster than I like to do due to the cure time. I mix in smaller batches and stuck with the 1% hardener (normally use more to speed up cure time) and decided to let it cure out after the first few layers. I will ruff it up with some 36 grit sand paper, clean it well then add the 1808 and some more tabbing. This time I will do it a bit earlier and beat the heat.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf Last edited by flyingfrizzle; 07-22-2013 at 11:04 PM. Reason: 1808 not 1708 (used stitched mat) |
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
Don't forget the butt paste....
See ya, Ken © |
