Do you think the fine grit is ok or should I go more coarse? Or try just the stronger pressure washer with the same grit?
![]() Quote:
You could try a higher grit, might go a little faster. Planning on painting or leaving it gelcoat? If your painting, the texture left after a soda blast with a quick once over with 80 grit is perfect for a few coats of interprotect 2000 then bottom paint. If your going to leave it gelcoat I'd stay with a finer grit, but get ready to spend some time under the boat.
Zachary [SIGPIC][/SIGPIC] |
