Old 12-30-2013, 08:07 PM
Tried to pop it out once it sat and cured in the heat over night. The lower lip came loose easily but the large areas wouldn't budge. I didn't think it would but wanted to see how loose it was. I cut out a place to add the air chuck. Glassed it in with some thickened resin and scrap fibers. I used a little bead mask to seal the hole off so the resin wouldn't plug up the fitting. Couldn't find the clay and the bead masking worked almost better. Hope this will let the mold rise off more easily plus it will ade in removing the molded parts once the mold is finished and used.
