I was very happy w an etec 150
Look at a Honda 115 or 135 if you want to see the heavyweight. Right at Yamaha 200 weight.
My first post! Re power for a new to me 1973 Seafari. After reading what
others have done and not wanting to overload my boat I am thinking about the new 2014 90hp e tec pontoon model to get the gear reduction to turn a larger prop (maybe four blade).. My fishing is mostly trolling at 2 1/2 mph most of the day and hopefully being able to plane at something above 20knots going in and out. Only have the 30 gal tank and may wish to try a few overnights............ |
That should work on a 20 footer. Rumor has it 70 is the minimum. I have 100 hp and like it.
Also in my thoughts was the 2014 yamaha four stoke 70hp at 256lbs....
Primetime, welcome aboard. The etec 90 will be more satisfying. 335 lbs on a Seafari is the best weight to power ratio your going to find and youll wonder if yiur fuel gauge is even working. I think maybe Bilgerat had an old 70 on his Seafari, but I think the 90 will prove a better choice as that 20-25 extra ponies will prove significant in that range.
I have a 367 lb F100 Yamaha. Jetted for non ethanol gas, but otherwise great. I think top speed with a F70 might be underwhelming. Or even a 2 stroke 70, if it exists.
![]() Quote:
Very useful information....thxs...bob
