Another pic- all cleaned up.
Got the subframe built; used a 4x4, 2x4s, and a 5x4 sheet of Melamine board- it's set at 12 degrees.
Filled in some old thru hull holes, a strake, and cuts in the hull.
Beveled the glass back, laid some cloth on the outside and then thickened epoxy with cabosil and glass fibers and a bunch of 1708 layers on the inside. I'll go back over the outside spots when I do the exterior hull. It's thick enough that I may put the seacock valve back at the same spot, esp. after the glass for the extension goes on. |
After doing some testing, I'm concerned with the condition of the original woven roving; most of it seems dry and chalky white.
So to make some more work, I chiseled off much of the roving for about 24", to get some clean glass to bond to. It came off fairly easily, compared to the leftover epoxy on the transom area. What's a few more hours? I hate grinding! |
Glass cleaned up; I'm ready to finish the mold.
If only this rain would stop. |
Mold almost done. Lots of carpentry work- almost fun!
All done with a cordless circle saw, straight edge, and angle finder. Need to add keel section, cut off screws, and then do clay and wax. Want to double check height of sides of tub. It's about 19" now, so should be right height, may need a bit more for the glass work. With swim platform I'll be about 20" and I have 5-7" more for the motor mount lip. |
I have a project 20 that I'm thinking of extending similar to what you're doing. My thinking at this point (at least one boat project away from starting on the 20) is this:
Dave
Blue Heron Boat Works Reinventing the wheel, one spoke at a time. |
