Got the stringers raised 2.5" and 4.5" at the transom. Stuck em down with cabosil and filled all the gaps with it too. Gonna start glassin them up this week!
I plan on installing the bulkheads and am trying to figure out where the center of gravity of my 60 gal fuel tank shoul be. Since I am putting a 24" setback bracket with new 4stroke and 25gal transom livewell in I know it needs to be moved forward just not sure how far. If anyone can has an idea please chime in thanks.
![]() Quote:
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
![]() Quote:
The CG on my boat is about 6.5' fwd of transom. That location is real obvious because the aft cross member on my EZ Loader roller trailer pivots, tilting the boat about 30 degrees when the CG passes over it. My boat is a stock Seafari with a 34 gallon tank plus 2 batteries, a 1.8 gal oil tank and a 9# anchor + 6' of chain +100' of line in the stern, and a 9# anchor on bow with 20' of chain and 300' of line in anchor locker. Motor weight is 427 lbs and bracket is a 30" Hermco; not sure of bracket weight but I'm guessing it's somewhere around 150 lbs. You could use those numbers to set up a moment balance about the current CG to solve for the CG location of the bare hull (assume it weighs about 1100 lbs). Once you have that you could then subtract the moments for the stuff you've removed and add the moments for your heavier motor, live well, gas tank, and console, etc., to figure out the new CG. I would strongly suggest using Coosa in the new transom and some sort of composite in the deck in the rear of the boat and maybe plywood in the front of the boat to make it a little less stern heavy. I'd also try to minimize setback on the bracket; Don Herman said he can make his with 18", 24" or 30" of setback. I'd also put that livewell in the front of the console, assuming there is enough room for it up in the bow of the boat!
