![]() Quote:
I concur with Terry and the others regarding repowering, as I went through the same thought process when I repowered in 2006. Although my overall average gas mileage went from 2.8 to 4.4 mpg by upgrading from 1975 technology, I could still buy many years worth of gas for the $12K or so it cost me to repower! The only way to really justify it is the clean quiet reliable operation of the new motor! And I have to admit that the dozen or so nice trips I've made with the new motor probably would not have happened either!
Thank you for the suggestions everyone!
I have a question for those of you who have a bracket: What size shaft is your outboard 25 or 30? For some reason the previous owner set the boat up with a 30 inch shaft outboard on a hydraulic jack plate, on the Armstrong bracket with 30 inch setback. It just doesn't seem right to me. Any input is appreciated. Thanks! |
I think the previous owner could have added more crap to the rear of the boat if he really wanted.
SeaCraft1972,
Don't be in "fuel tank denial". Beg borrow or steal a 6 or 12 gallon clean plastic gas tank, put fresh fuel in it and hook it to your OX-66 with a new fuel line a bulb. Run the engine and see if things straighten out. At least you will have isolated the problem of being with the engine or the fuel tank, lines, filter housing, etc. IIf you put a new engine on the boat you'll probably want to put a new tank in it anyway so you don't run a big slug of water through it. Water in the fuel is not covered by any engine warranties that I'm aware of. |
Re: bracket.
Not a SeaCraft, but older style 25' contender; originally had twin 25" Yamaha Hpdis and repowered with a single 30" Yamaha four stroke. Left Stainless Marine bracket at original height. Even with the motor mounted at highest position, the anticavitation plate is still below the water line. Thinking of putting a jackplate on. My buddy has identical boat, motor, and bracket, except it's 25" and his is too short, even set at the lowest position. You may need to adjust the bracket height if you go with a 30" motor. |
I will definitely test the boat with an auxiliary tank. Thank you for the suggestion Terry.
Question for Dave and Don and anyone else with experience setting the height of an outboard: Is there any way to determine what length shaft my boat/bracket setup should have? If I get a new motor i'd prefer not to set it up with a jack plate. |
![]() Quote:
