Old 10-17-2014, 08:28 PM
FAS FAS is offline
looks very nice,clean bottom and more for an 88,go for it !!
Old 10-17-2014, 08:39 PM
Take a 4' straight edge with you when you go to look at it. If you can find a 6' straight edge, that's even better. Lay it along the hull bottom just forward of the transom on all six hull panels and look for hook (concavity) in the hull panels. Rumor has it there was a mold being used for the 23s in the late 80s that had a hook on one side. If the starboard panels are consistent with the port side panels, you're good to go. If there's a hook on one side, the boat will heel to the other side when on plane and will be difficult to trim.
Dave
Blue Heron Boat Works
Old 10-17-2014, 09:10 PM
FAS FAS is offline
Dave
would this hold true on a October 84 build 23 sf?
Old 10-17-2014, 09:33 PM
I've never seen it, but heard it was in the late '80s boats. Easy enough to check with a straight edge.
Old 10-18-2014, 12:58 PM
There was 1 mold for the 23 that had a hook in it. Potter supposedly warned SeaCraft Industries about it when they took over his bankrupt operation in 1980 and told them not to use it. However that bad mold was apparently used occasionally during the 1980's because I noticed the hook pictured below when I looked at an 80's vintage 23 Sceptre for a forum member about 6-7 years ago! The most noticeable hook was on the center panel on the port side. There was about a 1/8" gap between my straightedge and the hull about 6" forward of the transom.
Old 10-18-2014, 09:53 PM
Yachtie Yachtie is offline
Bringing a straight edge. If I find a gap like that is it worth walking away?
Old 10-19-2014, 01:53 PM
Statistically speaking, I think the chances of any particular 23 having a hook are fairly low, but if it IS one with the hook, as Ryan said, it will provide some leverage to get the price down a bit. It's not a deal killer, as it's easily fixed with a couple of layers of 1708.
Old 10-18-2014, 12:01 AM
Dave
Thanks for that info. I will do that.
