Chance, thanks for the response,I will add more foam to the aft end around the tubes on both sides it may help float the transom an extra 1/2 inch.the 3" tubes were a tight fit as it was, the way the 23 Sf stringers are made a 3" standard pvc pipe will not fit.I found OEM style sewer drain thin wall stuff.My boat originally only had one side tube and twin engines,talk tight!!, but now I have two full tubes,getting ready to Rig it...
We thrive on boat porn. (More pictures)
Especially SeaCraft porn, however post #2 on the below link is not really boat porn!!! This is the kind of porn that gets you thrown into jail!!!
http://www.classicseacraft.com/commu...994#post231994 Just gotta give Frizz a hard time ![]() ![]() |
![]() Quote:
![]() ![]() Post #2 is the before - the after is soon to come!
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
Like I said.......
Just gotta give Frizz a hard time ![]() ![]() When you have an inventory like Amazon of SeaCrafts we have to give you a little ribbing!!!! ![]() |
Some boat porn for you guys...
Here's a shot under the floor. Shims in place and new rigging tubes. ![]() Fitting the floors. Still need to make the lip to hold the center hatch. ![]() Made up a jig for the top lip on the floors to hold the center hatch up. These are glassed with 1708 and should be perfectly smooth when I remove the jig. ![]() This is the jig in place. Just waiting for things to dry now. ![]() Here is the lip jig set up at a different angle. ![]() Tomorrow the floors can go down with all of the center lips in place and then here is a few more parts and pieces that are in the lineup to get done. ![]() |
I replaced that tank in my 23 and wish I had either put in a smaller tank or 2 tanks.
Otto And yes, I still believe in the four boat theory... |
priced up a tank today ,cut it down 18" shorter,and took an inch off the width.Cost dealer cost,$1,100 bucks,epoxy coated aluminum. another guy said 850, no coating, another guy powder coats them all,waiting for his price...Watta ya think about powdercoating,apposed to thick epoxy coating?
I've seen a lot of flaking powder coating.... I feel like you get what you pay for in most cases. I love the big tank in our boat (144gal), and it doesn't take long to drain it with the old two smoke on the back. However I do wish when my dad replaced it 10 years ago he split it into 2 or more tanks for weight distribution. I'd rather have too much capacity rather than not enough
got a lot going on right now, sorry for no picts, but .....the 23 is movin on in its resto,console, refilled, prepped , and ready for prime.not an easy deal...floors ,almost ready for complete put down and finish.hull is stripped in and out ,filled all sorts of of bad fittings ,getting prepped for new awlgrip,in and out.still need an original aft hatch , waiting on carl, he say he has one for me.if you guys are interested, i'll keep em coming, I am busy like you all ,too.I am all in on this one...yikes!!
