Old 12-13-2014, 11:04 PM
So I drilled a small hole from the inside after removing the hack job patch that covered it. The old hole looks to be filled with just resin. Does anyone know if there was a wood block under there like the original thru deck scuppers? Also can someone measure the inside diameter of this drain for me so I can drill the right size hole? Thank you.
