I will ask it another way...
For those with the 20 SF .that still has an in deck livewell... how is it operating ? Or what changes, other than removal, have you made to it to make it more functional ? Thanks, Bill |
Mine would always flood the deck. I'm rebuilding my boat now so i'm going to cut it out for better bilge access and just install a fiberglass bait tank in place of a leaning post.
I recently sold my 1975 20SF but I had my livewell working. I put a fitting in the drain port leading to a 3 way selector valve to a recirc/aeration pump plumbed back in to the livewell just under the deck. The fixture putting water back in to the livewell had a nozzle that would either recirc to the livewell or pump out the livewell. The selector valve either allowed water from a thru hull in or recirced or pumped out or just drained when out of the water. In no case was the livewell allowed to drain in to the bilge. I had a 175 hp Johnson 2 stroke outboard at 375 lbs. on my boat and never had any issues with wet feet.
Thanks all.
Caper, the power on the one I am looking at is a Mercury four stroke 115 hp that weighs 380 #'s, so I will have to see how it sits if i get as far as a sea trial. |
