I've cut out the new 1 1/2" coosa transom core. I keep grinding here and there to get it to lay as close to the outside skin as possible but when I look down the top I can still see from 1/8" to 1/4" gaps in some places and I can't get it any closer. Is this normal or is it supposed to lay completely flat. I'm thinking when I apply a thick layer of thickened epoxy and clamp it all down all voids will be filled. Any suggestions or opinions on how to continue? I'm sorry I haven't posted any pictures but I just can't figure out how.
Drill some holes in coosa to allow cabosil to ooze out; use bolts/screws through existing transom skin to pull coosa up against inside skin. I'd install a layer or two of 1708 against inside skin, wrapped around 6-12" into hull sides and bottom and then try to install the cabosil/coosa while the 1708 is still tacky to get a good chemical bond. Get a couple guys to help with mixing resin and laying glass; refrigerate resin to maximize working time. And I'd use epoxy resin or at least vinyl ester resin for maximum bond strength.
![]() Quote:
We pulled it all together with bolts,and clamps. I did this in late Feburary cold winter day,but it turned out to be a benefit,as the cold prevented the resin and putty from kickin too fast,giving us ample time to get it all in place.. I then turned up the heat,and got it warm for several hours.I tried to use bolts in areas wher I was going to cut out the plywood like the hole for the outdrive,and the holes wher the lifting transom eyes were,so that Id have less holes to fill later on. After the transom was in, I applied more layers of 1708 on the face of it overlapping it several inches in to the hull. I only used Epoxy to glue the two layers of 3/4" plywood together.Everything else was done with vinylester and polyester resins. I think I put a bit too much putty on it,but its been six years now,and (knock on wood)its still solid as a rock. Good luck with your project ![]() ![]() ![]() ![]()
Looks like I'm going to attach the transom and fillet it this friday and then remove the clamps and glass it in on sunday.
that is close enough you will need thickened epoxy or other type of bonding such as 2 layers of matt wetted out. make up either clamps or 2x4s inside and out bolted through to squeeze everything together
36' Yellowfin 1972 20' seacraft 140 suzuki http://www.classicseacraft.com/commu...ad.php?t=18607 |
I'm using the U.S. composites 3:1 epoxy. So I should stick a layer of 1708 on the inside of the transom skin then when tacky spread the cabosil thickened epoxy on it and clamp the core with pre drilled holes in it so the epoxy can ooze out?
This is a perfect application for vacuum bagging, but yes, use a notched spreader on the cabosil and apply it to still-wet layer of 1708; mat may add some extra bulk too, although not much strength. When we installed the transom in SkipnCarla's 21, we were advised by a professional glass guy to drill some holes in the coosa to allow it to squeeze out and show that we weren't getting air pockets between the coosa and inner skin. Bolted 2x4's or clamps are definitely a good idea.
![]() Quote:
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
I'm doing the same thing. Do I need cloth first or can I just use thickened epoxy to glue the new core in? I can add 2 layers of 1708 wetted out then thickened epoxy then the core but this seems redundant. I plan on covering the coosa when done with 1708 and 1208. My original skin is 3/8 of an inch thick. Is there a proper layup or is there more than one way to skin a cat?
![]() Quote:
If its an out drive powered boat,the transom can only be a max of (i think) 2-1/8" thick.After I finished mine with the two layers of 3/4 plywood,- the putty,-and the new glass skins- on the inner and outer transom skins,I was at 2-1/16" thick I went too heavy on the putty as you can see on the picture of the core Its the first wide grayish band that you can see on the picture of the large core sample. on the right side. It didn't hurt anything structurally,although it added extra weight. ![]()
