Thanks for the reply Robert. The decarb did not solve it unfortunately. Actually, after retest of compression, I can't get numbers as high as the originals. I decided to go with the yamaha f115. It passed a leak down test and is running well. picked up a lower unit and tested it yesterday. It is mounted on a novurania 18' RIB that is in pretty poor shape and I am getting the seastar steering and controls/instruments as well. I am basically going to strip the Novurania down and get rid of it. I have a lot of work to do to the seafari before the motor goes on...mostly cleaning, painting and rigging. Looking forward to it!
![]() Quote:
Dam that sucks... was really hoping that Decarb would do the trick for you. The yamaha will be a great engine. You did exactly what I do. Buy the whole boat... pull the engine, and part out the boat and trailer. If u are installing steering... The 4.2 No feedback Cable is more than enough for that 115. I could not fathom a reason for installing a Seastar Hydraulic steering if its not needed. Just more things to go wrong on the water. I have run the No Feedback Set up on a Johnson 225 ocean runner and it worked great. If you like eating Spinach forget the Hydraulic for a 115 not needed.... Keep us posted. Robert |
You are likely right about the steering...I have always preferred cable. I may be able to reuse the steering from the Johnson but I haven't got to check it out yet. It is missing the steering wheel so that does make it tough to turn! The seastar is in good shape but I would need longer hoses so either way I am going to be spending something.
I might have to give that solas 4 blade a try...the prop on the motor now was pushing a really light boat and looks to have a lot of pitch. I have no experience with 4 blades. I hope to get started stripping the boat down next weekend. Thanks for the suggestions guys! I appreciate it. |
I've got another question I've been meaning to put to you guys...my Seafari has bennett trim tabs and the small hydraulic tank (it looks rough and is bone dry) but is missing controls. Do most folks use trim tabs with the seafari? Should repairing/replacing be on my immediate list when i put her back together? Thanks!
![]() Quote:
Most folks just think of trim tabs as only being useful for pitch control, i.e. helping stern heavy boats get on plane easier and for helping them stay there at lower speeds as well as help hold the bow down. While all this is true, they are also very useful for roll control, not only to compensate for more weight on one side, but also to adjust the angle of heel to improve the ride. Since I installed the bracket and 25" shaft motor, I find the motor trim is very effective at controlling pitch/running angle, so I mainly use the tabs for roll control. A deep-V hull will tend to lean into the wind. Reason is wind tends to blow you off course, so when you steer to windward to correct your course, the boat naturally leans into the turn. When the wind is coming from any point forward of the beam, I will often use the tabs to roll the boat in the other direction, away from the wind and waves, which basically increases deadrise of the hull relative to the oncoming waves. If the wind is aft of the beam, I will use the tabs to roll the boat into the wind, again to increase deadrise relative to the following seas to improve the ride. Just a few degrees can make a big improvement in ride. It just takes a subtle tweak of the tabs that not many skippers I've ridden with seem to have figured out, but it's worth experimenting with, as your boat will ride like it's several feet longer! As for priority, obviously getting the motor running, and fuel and electrical system checkouts will be top priority, but once you start running the boat any distance, you'll definitely want to have those trim tabs working when the water starts getting choppy!
