Considering the 2015 115 Mercury 4s for my 1985 20 SF. If anyone has any experience with this motor or setup what are your opinions?
The Tee Top and windshield may hold you back a little, but I would guess you would be in the neighborhood of 30-32 mph WOT with a perfect prop. Probably cruise comfortably at 20-23 mph and get 4 mpg. Unlike the Keys we make a lot of 60-80 mile days when we go bottom fishing off shore because there is very little structure inside of 45' off of Tampa. Good milage helps you use the boat more often. Just sit back and enjoy the VDH ride.
What is the weight of your hull? I would expect mid 30's for a standard gear case, faster for a command thrust Model. Merc performance reports put a command thrust 115 with Enertia prop on a 3300lb scout boat in the mid 40's top speed and best economy of around 6 mpg at cruise. I'm hoping to have some numbers in a week for a command thrust and powertech 14.25x21 pitch prop
Definitely not going for any speed records, distance and fuel economy is what I am after. It's an 85 year model. not sure of the weight. Want to put a platform on the back, 60 gal tank shifted forward, remove the casting deck and put a fish box cooler up front and a livewell type leaning post/rocket launcher.
The leaning post.
![]() Quote:
[IMG] ![]() |
Looks good. Have you splashed her since the new motor?
I suspect a slightly higher top speed. But I bet a 17P prop is close to what you want. I run a 15P on a yamaha F100 on a 75 20MA. And hit 33MPH at WOT. I suspect you will do a bit better.
Not yet, Just brought the motor home today. Still have to rig it. I floated it with simulated motor/gas/gear weight to make sure she was ok with it and she sat perfectly.
I expect it to be a winner. Lightweight w appropriate displacement to make up for being 4s. Good luck! Look forward to hearing performance nos.
