Old 12-28-2015, 09:04 AM
Originally Posted by pelican View Post
let me add something...
water in the bilge,sea water,boat's covered - heat builds up quickly...water evaporates,yes ?
salt is left behind,salt wicks moisture - it has a corroding effect and a prying effect
moisture rises too...
covered rack storage - bad environment ! corrosion city !!
enclosed motor area - like an I/O set up - gets pretty hot in there huh ?
get what i'm saying ?
All good points...normally when I am done boating for the day the boat gets a good rinse,motor flushed and the bilge drained...then i try to leave the cover open until the motor cools down. Now I will have to add the spray to my list
Old 12-28-2015, 11:29 AM
All good points... Now I will have to add the spray to my list
Ter #1, Señor Pelicano is right. Hold out and get the Lear Research "Corrosion Block" - it is the best. It is a little hard to find but worth the search. It comes in a cool rustproof aluminum can, like a little fire extinguisher. The problem is it only costs $4.00 less than the fire extinguisher, but it's still worth it.
Ter#3
