Old 09-05-2016, 10:19 PM
pelican pelican is offline
Originally Posted by jwclbi View Post
Hello, I have 1998 225 EFI Mec, trouble is the tach is intermittent. I removed the tach cleaned the connections, no different. Friend of mine has a new one in the box so I installed it with same result. Is there a "sending unit" for lack of a better term, somewhere on this engine. I looked for a couple minutes but couldn't really see much. Any thoughts would be great, thank you.
that motor,it has 2 regulator rectifiers - back of the motor - swap the grey wire with the other rectifier - it's probably the rectifier
grey wire isn't "hot feed" - grey wire is tach signal
purple wire is ignition
black is ground
not uncommon for those to go bad
check charging system - make sure it's working properly
the high output charging systems,they use 2 regulator/rectifiers
Old 09-06-2016, 09:37 AM
jwclbi jwclbi is offline
Here is a picture
Old 09-06-2016, 05:49 PM
Tach diagram:
http://boatinfo.no/lib/mercury/manua...3lit.html#/158
Gauge arrangement:
http://boatinfo.no/lib/mercury/manua...3lit.html#/148
Engine harness:
http://boatinfo.no/lib/mercury/manua...3lit.html#/172
http://boatinfo.no/lib/mercury/manua...-3lit.html#/98
The 225 3.0 is different than the 150-200s of that same year with the 40 amp system dual 20 amp rectifier boxes (looks like what you have pictured in your post) The 3.0 will have an alternator and the grey wire will come off of the box shown as #34&35 in the manual provided in the link above. Sounds like you could have a corroded wire or connector. Check all the connections in your harness to make sure they are clean and well connected also.
Old 09-06-2016, 07:16 PM
black is ground
Tomato
