Old 11-20-2016, 06:45 AM
natecert natecert is offline
kmoose, i have got the bracket ordered an will be ready around the first of the year. Plan on picking it up and spend an over night on the east coast and look for boat items over there.
While ordering the bracket I found the transom is bowed and will need to address that as part of the process of the replacement. Good thing I am replacing the wood otherwise a bracket would be impossible due to it being non uniform port to starboard.
Got bored with hammer and chisels and started the live well. The flat will be used for all water in and out. 1.5" over flow set for full and 1/2 tank level and two feeds, one 3/4" and one 1" from two separate pumps. The ball valve on the underside will make it quick to dump the the tank and have no residual water to slime up the bottom of the tank.
Also laid up 1707 and csm on the sides and bottom to give the aerator tank more strength, was not intended to be on a pounding boat.
