Old 08-16-2018, 04:35 PM
bgreene bgreene is offline
Default More ride comparison ....
Older 70's-80's vintage 25' Mako.......vs Seacraft Sceptre
Experienced contact gave solid edge to the Mako.
Drier, less bow wallowing in following sea.
Any others who have experience with both ?
Old 08-16-2018, 06:24 PM
Owned and commercially lobster-fished in the Florida Keys a 1976 25' Mako side-console with twin 1976 105hp Chrysler outboards back in the mid-70's.
Also owned and enjoyed a 1974 SeaCraft Tsunami 23' from 2006-2008, rigged with a single 1988 Evinrude 225
The Tsunami/Sceptre had a much softer ride than the Mako. Not even a close comparison.
The Mako was a much drier boat than the SeaCraft, even when the hull slapped in a chop.
Both boats suffered from yaw in a following sea, but the Mako was a little bit better, not so much because of the hull design, I think, but because of the twin motors. The Mako also had less roll, but that was the flatter hull.
Fr. Frank says:
Currently without a SeaCraft
Old 08-16-2018, 08:01 PM
Fr Frank - That's very interesting.......thanks for posting.
If you had to take either for general sea keeping capabilities again - which and why ?
Old 08-17-2018, 10:53 AM
BG - Those makos are generally rot boxes and the old mako 25 is another shameless splash (with some modifications) of Walt Walters Formula 233 hull. The Mako 25's with the 24 degree (even though they claim it's only 23 degrees) is a good ride.
Old 08-17-2018, 03:49 PM
I hear you Big, but I'm not talking hull rot etc on this one.........just ride comparison.
Seacraft transom's etc same/ similar issues, scuppers etc.
Just ride comparison - getting interesting reports from knowledgeable owners who have had both. I haven't, so wouldn't know unless I fished them both for a day on the ocean, in typical NJ 2'-4' chop and such to compare:
head into sea
quartering and how wet
following sea
drift characteristic
Overall ......seems from the Mako site and Seacraft the 25' Mako has ride edge, but no matter, it was also 2' longer.
I'm a cuddy boat man these days......fishing the ocean in the heat, the winter, avoiding some sun, avoiding lots of spray, and staying dry.
Running and gunning bird action in the early winter.....my current 96' V21 with curtains - a pleasure as it's also a bit of a heat producer inside.
Old 08-17-2018, 04:46 PM
Tim, my 25' Mako hull had, at best, an 18 degree deadrise, and was more like 14-15 at the transom, with a single mid-chine on each side.
For sea-keeping at displacement speeds, the Mako wins. For sea-keeping on plane, the SeaCraft wins. Overall, I'd choose the SeaCraft.
Fr. Frank says:
Old 08-17-2018, 09:16 PM
Frank - I've seen 22's? with the low deadrise (like 12 degrees) and I think the 1980's and early 90's 25's are a different hull like you described. The 1970's 25's I've seen are a dead ringer rip from the formula . . . waterline down.
Here's a 1977 mako 251
http://www.classicmako.com/forum/top...TOPIC_ID=56396
Old 08-22-2018, 07:54 AM
Tim, I've seen the specs for the regular 1976 251 Mako, and they don't match the boat I had. My grandfather bought the boat for me, and assuming I haven't lost my mind completely, it was called a "Mako 25". Not a 251, or a 254.
It was purchased brand new from Tuppen's in Lake Worth as a commercial workboat, and it had a 25" transom, and was rated for 300 hp, although we had twin 105hp Chryslers installed. It had two 70 gallon fuel tanks, and the liner was a completely flat deck inside with no risers or below-deck storage at the bow, and side console on the starboard side. It looked like a stretched version of the older 22'.
Fr. Frank says:
