Old 11-18-2018, 09:18 AM
The only way a surface drive will work is to spin the motor inputting into a ZF transmission outputting into a simplicity drive. With the way the motor is moved forward it looks like it would have room for the transmission so it would likely be doable. You can find deals on used simplicity and other drives but even if you got a deal the motor would need serious upgrading and the pricing on SP props is beyond stupid. Cool as it would be the easiest and cheapest way to get a 31 kt cruise is with a DF 300 and a bracket.
Seems like alot of work.
Transom, bracket, fill the hull bottom, be cheaper to sell this boat and start with another.
Could do a waterjet. :-))))))
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 11-18-2018, 11:08 AM
FLexpat FLexpat is offline
With the right prop and ventilating the pocket, you may not need the Arneson drive and all the mod work for that.
Put a 1-2" vent hole and ball valve for control in the pocket by the shaft log and find a semi-surfacing prop with rake similar to the shaft angle. (Prop Gods or Herring)
The owner would need to be willing to be a guinea pig though.
https://www.boatdesign.net/threads/p...tunnels.19863/
Old 11-23-2018, 10:37 PM
Where are the bunny pics?
Welcome home.
Old 11-29-2018, 06:16 PM
aldo aldo is offline
IMHO Enjoy it as a 20 knot boat, or bracket & outboard if the need for speed is overwhelming. I speak as an Inboard owner for over 20 yrs.
Old 12-03-2018, 09:20 AM
I completely agree. If I had to go slow it would opt for a diesel replacement though. If I'm going to go slow, I'm going for the best mpg.
