Old 02-19-2019, 06:27 PM
Default Versiplug-R Drain Plug
Thx Michael. Online I found a versaplug made by PWC which has a ball check valve made for SeaDoos. Will look into it more. Sounds like a natural for my splashwell drain when the heavies are sitting in the stern jump seats. Hsve to check dimensions to make sure it doesn't stick too far aft.
This is a Versiplug-R which looks the most compatible. I have requested dimensions like how far does it stick aft from the transom. Vezo could you or a 20' owner with an ETEC 150 determine the clearance between the back of the transom at the drain hole to the all the way trimmed in engine? Maybe measure through the drain hole or use modeling clay. My engine is on a stand right now. Much thanks
