![]() Quote:
My dad deals with this all the time as he build/modifies tee-tops for a living currently. I know that if you can go to a larger dia screw and retap the plates to fit you may be best. That is if the holes in the feet will countersink that large. THe epoxy deal may work as I see it used on construction sites for thread repair. Third option is using an anchor bolt that has a collapsible head that you can pass threw the stripped hole that opens up behind the plate or under the deck. They may be hard to find in stainless steel tho. One other last resort prior to new plates are using heli coils. Drill the striped holes to the next size up and install stainless steel heli coil threads back to the correct size. They may not stay in there well and want to come out unless thread locker is used. Which I would use thread locker on them anyhow as it is very common for them to strip out and pull from plates that are thin bed into the deck. If you beat the boat offshore they will pull loose if the plate is thin.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
