Old 06-20-2019, 06:15 AM
Bigsean Bigsean is offline
Default Stickers
That’s the one buddy! Thanks a lot!
Old 06-20-2019, 08:57 AM
Actually, the font is not Garamond. The actual font is as attached. The serifs are more rounded than on Garamond.
Old 06-20-2019, 04:23 PM
Garamond is real close. I cut mine on my dads vinyl cutter/printer using the Garamond font and then just hand trim the vinyl while on the backing paper so they match the originals a little closer. If you used Garamond and didn't modify it you probably wouldn't be able to tell the difference unless you had originals to compare to side by side.
You can use Garamond here as a font while typing a post. It's in the drop down box up top: Sea Craft
Very Very Close if you just want the name and don't want the square "S" emblems in front of it.
All of my boats in the signature section are typed in Garamond below
