Old 06-08-2020, 12:47 PM
lelandtampa lelandtampa is offline
I ran my scuppers right out the transom. And filled in the straight down scuppers. The blocks were both leaking directly into the hull just with hose directed spray. Makes it easier to see any leaks or to plug the scupper from the outside if you have a problem. Not to hijack but Tally can you still see the waterline on your hull if so how high up the transom is it?
