Old 06-10-2020, 03:20 PM
FWiW- knowing jt’s a little late for you. In my Seafari step down I carefully cut through the top sheet with a cut-off tool on a Dremel. Then was able to peel off the top sheet without cracking it. Actually did this fwd of the door at night with the boat in the water. Then did aft of the door a few years later after it got springy. HOWEVER, IF YOU CUT FIBERGLASS WITH A DREMEL, USE A FLEXIBLE DRIVE CABLE TO KEEP THE DUST OUT OF THE DREMEL. Learned the hard way!
