![]() Quote:
Most of that potter putty came right off with a chisel. If you see the metal square backing plate on the motor mount pictures, that was "sealing" a thru hull that was not being used. My HIN is: SECF30100778 so 10th boat made in July of 78? |
[QUOTE=Thomas
My HIN is: SECF30100778 so 10th boat made in July of 78?[/QUOTE] Correct, you have been doing your homework
This is how the transom looks now, most of the plywood is gone. I need to attack the keel stringer next.
Any advice on the thru hull transducers seen in the bottom right, is the transducer in a "pocket" in the hull or its it all glassed together- i cant seem to knock them out? |
