Old 04-15-2003, 10:34 PM
Default Re: Transom Mounted Transducer Placement
I have mine placed on the center chine,(inboard), not sure about an outboard.If it is then I think I would install it on the outboard as far as you can on the 2nd chine to get clean water . I think the most critical part is getting the angle and yaw correct so that you get the least amount of disturbed water running over it. Its nice being able to read the bottom when going at high speed instead of having to slow down to pick up the bottom. Just my opinion Hoop, Im sure there are a lot of other opinions, ideas lurking here!!! (28 visitors and 10 members ??? (THT must be boring tonight [img]images/icons/grin.gif[/img] )
Old 04-16-2003, 08:03 AM
timd timd is offline
Here is where I put mine on my 20.
I mounted the starboard to the hull, and the td to the starboard, in case I needed to adjust it. I got lucky and hit it dead on. Reads bottom to 30+ MPH.
[ April 16, 2003, 07:05 AM: Message edited by: timd ]
Old 04-16-2003, 09:52 AM
Hooper Hooper is offline
Tim D-
Nice idea about the starboard, I can see how that would help in placement. I think I will give that a shot, thanks for the tip.
Miles,
I hear ya about the smooth water, it is important so that you don't have to come off plane to scan the water beneath you. I have some vacation time next week and I hope to have the time to do this project then!
-Hooper
Old 04-16-2003, 02:22 PM
ScottM ScottM is offline
Dieter Sprockets
Hoop,
I mounted my 'ducer to the inboard-most side of the 2nd chine (see pics on the 23' page). I wanted it as deep in the water as possible without getting too close to the engine. As it turns out I don't get any reading beyond 18-20mph so either it's too far out of the water on plane or there is too much intereference by the engine. It's not the end of the world though since we also have an old Koden color CRT with a thru-hull 'ducer that reads at all speeds.
Old 04-16-2003, 03:47 PM
TUGBOAT TUGBOAT is offline
Might as well do it right the 1st time,Thanks for asking this ?.(nice 20)
I would prefer to 5200 etc, to the Hull NEW transom ! Can lexan be siliconed/5200 etc.? is starbaoard better ! I will screw the td on it so there goes Force , which one holds screws better ?
Scream'n Reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 04-16-2003, 04:17 PM
SECF3114M73J SECF3114M73J is offline
I shoot mine through the hull, works better than any transom mount I've tried. Gives a good picture at crusing speed. The less junk on the transom the better IMHO.
Old 04-16-2003, 04:38 PM
Eric McNiff Eric McNiff is offline
SEC - can you elaborate on that? I am trying to decide between a transom mount and a thru hull. Where did you mount it - in the bilge close to the bottom of the bait well?
Do you use a standard bronze thru hull transducer?
I heard you are supposed to mount it in a reservoir of oil (vegitable?) so the signal has something to be transfered through? Or can you shoot right through the hull?
I had my doubts about the performance, but when I read your reply I am having second thoughts.
Thanks
Eric
My wife does not care for the 2 boat theory
