  #111
Old 03-22-2020, 09:54 PM
Nice work.
Where are you finding gloves?
Old 03-22-2020, 10:14 PM
erebus erebus is offline
Question:
When you remove the core on the edges of things (bulkheads, gunwale etc.) what tool or process do you use to do that?
I've used a cut off stubby Allen wrench chucked into a drill to remove core in a cored hull for a thru-hull or transducer or whatever, but I cant imagine how you would do it for a whole gunwale or bulkhead.
Zachary
Old 03-22-2020, 10:41 PM
lelandtampa lelandtampa is offline
AutoZone had XL gloves today. Black, blue and orange ones.
Old 03-23-2020, 08:48 AM
Originally Posted by erebus View Post
Question:
A trim router with a straight paddle cutting bit and a steady hand mostly. If i cant fit the router ill use a die grinder with some kind of burr chucked in it. A sharp stubby 1/4” drill bit works well too. Im only going 3/8”ish deep in most cases, and in high impact areas.
Old 04-04-2020, 02:39 PM
Box with a couple drawers going in here.
Untitled by dirtwheelsfl, on Flickr
Gave her a bath
Only took 54 beers to flip her
Been dreading this part here!
Old 04-04-2020, 04:04 PM
54 beers?? for the whole crew? That's not all that bad!! Looking like it's going to be time to add some hours on the old sander!
Old 04-04-2020, 08:49 PM
Talking
And the grinders and the fairing boards!
Giving myself 1 month to paint it...
Old 04-04-2020, 09:54 PM
Gave her a bath
You took on an ambitious project there. Did you ever learn what she hit?
Old 04-05-2020, 09:26 AM
Yea woulda been nice to have a cleaner hull, couldnt tell just how bad it was though. I think he said submerged piling? I forget... He owned it for 40yrs
Old 04-25-2020, 01:30 PM
Fixed the damaged areas first, starboard side ended up having to get about 6ft of the bottom step ground out and repaired too. Stem/keel got ground and glassed too. Faired al that and glassed the whole bottom with a 6 and 4 oz finish cloth for uniformity. Pretty much ready for highbuild after i sharpen the step corners back up...
Sprayrails got shaped and glassed too.
Transom getting tabbed. 2 more full skins with tabs (theres 3x1700 on there currently)
