Old 12-27-2004, 06:16 PM
Default Re: 20 footer on E-bay
will I need to begin to think realistically?
Welcome to CSC ba17
20' have self bail issues. The number one item on your list should be ---> RAISE THE FLOOR
Click Here
Old 12-27-2004, 10:17 PM
BA17 BA17 is offline
Capt. Chuck,
Thanks for the link. That boat is really nice. I think I just decided who will do the redo on this boat. I had planned on doing most of the work, but after seeing that boat, I think I need a professional. I will definately raise the floor. Keep the info coming. Thanks again.
BA
Old 12-28-2004, 09:43 AM
mdurfeeh mdurfeeh is offline
BA17 Congratulations on the boat.I have a 1972 20 ft seacraft center console with a 115 Johnson and that boat will get up and go. I would ask others about what size motor you should have before you make a decision on 200hp.I would think 140 would be about the max.
Old 12-28-2004, 12:32 PM
muddywater muddywater is offline
Congrats BA! In the end, I couldn't pull the trigger on it myself because I have too many other things to worry about at the moment. Good luck with her! Btw, you aren't from South Louisiana are you?
Old 12-28-2004, 12:51 PM
Thanks,
No, I live in Marietta, GA and not real happy about it. I would like to get back to the coast. I am ready to pick it up and get started.
BA
Old 01-03-2005, 10:47 PM
Dunk Dunk is offline
A 200hp 500lb(with the prop and oil) Yam sitting 30" behind the transom is way more than the boat was designed for. 500lbs 30" back is the same as 700lbs bolted to the transom. You'd be better off with twin V4 Johnson 115's bolted to the real transom. It would float higher. Most older boats are not designed for a bracketed outboards. Especially with the weight gains new engines have seen. In 72' the nastiest thing around was a 125hp OMC V4 that weighed 300lbs.
I think I just talked my self into something............
Old 01-04-2005, 08:41 PM
gbf03 gbf03 is offline
You might want to talk to Don in ft Pierce at hermco. If I remeber correctly he was planning on putting a 200 on a bracket with his 20.
20 SEACRAFT SF / 29 SEA VEE
F.S.U. / REEL SWEET FISHING TEAMS
Old 01-04-2005, 09:19 PM
Finster Finster is offline
I am not sure of the buoyancy of the single for the 20, but I would think it be in the neighborhood of 350lbs +- at the water line, at a guess. At that the weight of a 200 would be fine.
I understand well what Dunk is saying, it's like haveing a 3.4 liter merc, weighing 575lbs sitting on a Gill bracket with no floatation....Not recommended! Though the boat didn't sit as low in the stern as thought.
I know the Don's brackets have 800lbs of buoyancy for a twin, 500 for a single for the 23's and as I said I am just guessing at the 20. But even if it was 250lbs buoyancy it would still work fine.
How's that for a fine Finster editorial!
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 01-04-2005, 10:54 PM
Scott Scott is offline
In the HermCo's literature for the Seamark (Potter bracket)
the Single version is listed as 6' wide (25" shaft) and has a buoyancy of 420 lbs
the Twin version as 7'2" wide with a buoyancy of 890 lbs
These are the only two models listed in the copy I have.
Isn't the Single version the model that has been used on the restores of the 20's on HermCo's site?? I didn’t realize there was one manufactured specifically for the 20.
Old 01-04-2005, 11:27 PM
ocuyler ocuyler is offline
Hermco did this renovation and installed these brackets on Bill Potter's personal boat, a 20' Seafari.
Otto
